G'day guys and girls, my names Seth and im about to become the proud owner of a pretty rough r33 gts-t.
The exterior has seen better days but the engine and driveline are like a dream, and with a little tlc she will be helping me enter the wonderful world of circuit racing/hill climbs/time attacks/drag racing/drifting. Pretty much everything i can enter her into i will and i will have an absolute ball of a time reguardless if i finish first or last.
I look forward to reading just about every build thread and diy thread this forum has, and i also look forward to getting to know a few of you over the coming years of skyline love and abuse.
Peace out.
Seth.
https://www.sau.com.au/forums/topic/360245-gday-lads/
Thanks for the welcome guys, i just finished up at my mates after shaking hands on the deal and taking a very good look over the car.
She has a touch of cancer in the boot which should be easy enough to fix, the rest of the car is cancer free and in pretty good nick. The battery terminals will be recieving the first bit of attention, which should solve a battery draining problem that has plauged the car for a while (if not it's out with the multimeter and the wiring diagram). Then it's on to doing a full service of the engine, tranny, diff and anything else that needs some loving. I have the itch to modify already, something i havent had for some time and i just can't help myself haha.
Peace.
Seth.
https://www.sau.com.au/forums/topic/360245-gday-lads/#findComment-5752459
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
