Hey All,
Well ive finally decide to sell my little Black R32 Gts-t, but 2 months ago i forgot that i was defected for my Pod, next comes a letter in the mail....
"Notice of registration Cancellation" !!! over a ****ing pod that leaks a little bit of gas ??....
Now, the plot thickens, prior to this defect i have thrown a HKS front mount intercooler in the bay, and in order to clear my defect i had to put the standard airbox on, and just as things couldnt get any worse .... It didnt fit because of the piping... now i know alot of you will say .. "just make up a custom box" but i gonna take guess here that .... It needs to be engineered ? and the plot thickens again, theres no engineers for 2 hours were i live ... Great.
One more question, can i take off the piping on the FMIC thats in the way temporarly, put the standard box on and take it to get cleared or will the car **** up ?
So i should do what exactly ?
Please tell me that at least 1 person has been through this or similar ....
Cheers all !
Mitch
https://www.sau.com.au/forums/topic/36028-im-sick-of-god-damn-defects/
I met a whole buncha bastards who wouldn't sign off on my defect unless it was back to the original airbox.
Liek yu0 kn0... get farked...
Not after a spent the money on a new pod and fiberglass box.
Unfortunately most places who can clear defects won't jeopardise their license for only $16.50...
T.
Well, i just had an idea to cut away a bit of the airbox so it bypasses the piping... so im going to do that 2morrow....
BTW. Are the RTA leanient with defects that lead to rego cancellations ? will that let me just reactivate the rego for a small fee ?
Cheers all and thanks for the replys
Just cover the pod with a box and go to your local blue slip garage and get them to check it. It took me longer to pop the bonnet lever and raise the bonnet than it took for them to inspect everything.
To be honest their is nothing illegal about a 'pod filter' but lets not get into that again...
:D
I had one and got defected. I went to a place near me, sat the box in dodgily and just swapped it over when I left again. he was cool about it because he checked it with the standard box, didn't he? if I put it on again after he leaves it isn't his problem
I now have a standard box with K & N panel filter. I also have a HKS FMIC, but the piping fits perfectly with the box, is yours a proper kit??
why you stressing for about the pod and rta, trust me you dont have to think about them, i get those leters all the time about defects and cancelation of rego, then licence if you dont fix it, but if your in sydney message me i have someone who will clear your defects and you dont even have to change anything.
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
