Up for sale is my stock r33 gtr rims wrapped with mickey thompson et street radials.
tyres are 274/40/17 all round. They have done 12 passes and about 150 kms of street driving.
no burn outs have been done with the tyres only launches.
they are still basically brand new.
The rims are in very good condition with little to no marks on them at all.
i will not sepperate rims and tyres, if you only want the rims, then buy the whole package your self and sell the tyres on your own ( you might even end up better off doing this)
ill get some photos up on the weekend when i get them off the car.
looking at $1600 for the lot, pretty good considering rims sell for $1000+ depending on condition and tyres are over $350 each.
im located in wollongong and will only do pick up, i will not courier these.
any further questions please feel free to ask or pm me.
https://www.sau.com.au/forums/topic/360903-stock-r33-gtr-rims/
here are some pics of the rims, they are still a little dirty.
there are no scratches on these rims, pretty much as new
also come with full set of wheel nuts
$1500
post-22977-0-83735200-1303799126_thumb.jpgpost-22977-0-91371300-1303799180_thumb.jpgpost-22977-0-43204500-1303799240_thumb.jpgpost-22977-0-89015800-1303799286_thumb.jpgpost-22977-0-07855200-1303799339_thumb.jpgpost-22977-0-00212400-1303799392_thumb.jpgpost-22977-0-99894400-1303799438_thumb.jpgpost-22977-0-78725600-1303799490_thumb.jpg
Have had a couple home issues come up in the last few hours so I'm dropping the rims n tyres down to $1300 to try n get a faster sale.
Still pick up only tho
People please read the original post!!!!
I will not post these, if u want them u can come n pick them up.
Also I am not separating rims n tyres, if u want the rims they come with the tyres.
The lowest price without the tyres is the same with the tyres $1200 so u may aswell just come n take them with the tyres
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
