Hey guys bought an r32 so this is up for sale. Was planning to go turbo but i picked the r32 up as a great deal. Engine has a slight tick due to the m20 engine valve design. You can pick a whole m20b25 (the 2.5ltr version) for about $800 with an ecu and its a straight swap.
Comes with
Rebuilt injectors
New o2 Sensor
New drive belts
Walrbo fuel pump 350hp rated. (internal)
Pod filter.
Fully sick cut exhaust.
Nardi steering wheel,
Stewart warner oil pressure gauge,
Has an mtech 1 oem bodykit.
Removed clutch fan and has 16" thermo fan installed.
Serviced every 10000kms. Timing belt done 10000kms ago, W-pump and tensioner was done as well
In dash dvd player.
Air con has been removed as when you go turbo the manifold sits were the air con pump is. Blower fan still works.
Paint isnt the best. Has oxidation on the bonnet. And the previous owner shadowtrimmed it which is bubbling a little.
Has remote central locking.
Power windows
Battery in oem position in the boot,
6 spoke rondell rims with new kuhmo tyres
Superlow king springs in the rear
Red leather hand brake and gear boots
Comes with a full workshop manual
Bad points,
D/S belt wont retract unless you help it
Both chairs struts are broken so they wont come back up by themselves,
P/S door trim is loose.
Typical m20 engine tick
Can sort out freight for buyer at cost
Vehicle is located in townsville. Drives perfect just need it gone asap.
I reserve the right to cancel the auction as this vehicle is listed elsewere
Call me i want this thing gone!
0419742800
Edited by beemae30
https://www.sau.com.au/forums/topic/360944-1989-e30-320i-5-spd/
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
