33 could be off the road :(
32 isn't on the road as I have no monies :(
You can all donate to me so I can get it on the road in time for the cruise.
What's wrong with the 33?
Well with any luck they'll go to a good cause and not to defecting station.
Salvos easily better then defect station... Thought i was gona get done in the diahatsu for a baldy tire yesterday :/
Not good brudda....nothing's wrong with bald tires....they're safer because you don't have to try as hard when you want to drift ;)
Charity cruise is getting closer. Hopefully get the wires out of my toes 2 days before the cruise so I should be alright to drive. Did get the Vspec out for it's first drive in close to a month today to go down to Armstrong's to pick up some parts, one part was wrong but got the right one on the way now. And it was a challenge to drive really hurt my feet but was soo good to get in and go for a drive.
Sounds good Chris!
Should swap cars so that mine gets a break? I've realized I could never drive anything other than a GTR :(
Sounds good Chris!
Hahaha no the Vspec is very happy with the about it gets driven. Have done 500km's since my last oil change which was 3 months ago, now up to nearly 1000km's for the year. About time you came to your senses.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
