I've seen ur toes.... They make baby Jesus cry
And your monstrosity doesn't, my toes look 100% then your V8 black and orange abomination. And that is saying something!
No it doesn't. His monstrosity is the reason that there is no god. Baby Jesus saw it and offed himself. :P
Muhahahaha.... :devil:
Went and watched was carr at Bon Amicis last night.... Was fckin terrible lol
Did you straighten your hair before you went? If you didn't might explain why it was terrible
Nope no hair straightening last night, was epicly fast shower after work bit of wax hit with a towel straight to tbar to hang out with Mary lol
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
