I've seen ur toes.... They make baby Jesus cry
And your monstrosity doesn't, my toes look 100% then your V8 black and orange abomination. And that is saying something!
No it doesn't. His monstrosity is the reason that there is no god. Baby Jesus saw it and offed himself. :P
Muhahahaha.... :devil:
Went and watched was carr at Bon Amicis last night.... Was fckin terrible lol
Did you straighten your hair before you went? If you didn't might explain why it was terrible
Nope no hair straightening last night, was epicly fast shower after work bit of wax hit with a towel straight to tbar to hang out with Mary lol
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
