How do I know what size I need? Measure the back of the turbo and the size of the exhaust?
Does that even make sense? Lol
Edited by A Grave Digger
We will probably be organising another dinner out at Ipswich in the coming weeks for you Toowoomba guys. Any of you interested or is it a waste of time?
Yep I'll come down for a feed and chat
I could be keen, shotty lift so I can drink
Shotty a lift also
Nope it's a t70 on a 25 neo motor in a 32 sedan
Have a search here on the forums or google to see what other people with that turbo are running. Plenty of aftermarket dumps getting around surely there would be something out there and would be cheaper then getting one made up.
March happy laps is on the 24rh of march. Afters which we are holding the agm. If we were to then cruise on down to Toowoomba and see what your city is like, would you guys be keen? Have lunch at a pub somewhere etc.
Why not make it the 24th. :)
This one is more about getting drunk and talking bullsh*t then cruise
Sweet, in
Of course you would be, you are always keen
24th of march.
Where is it going to be at?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
