Been patiently waiting for you to organize another run but I can't make it now.
Old girl is out with a busted turbo/manifold gasket. Sounds like I got a screamer on boost :D
Shit no good bro, what's the plans now then Just fix it and get it back on the road? :(
This weather has made it hard to do a run. Water is over the road in places on our usual haunts. Dude that sucks, lucky it's only a gasket and not something worse
gah. happened to me a couple months ago as well, but mine sounded more like a grain truck than a screamer :'(
Yer water on the way down blanchview isn't going to end well for us rwd dwellers lol. Worse ones are the little streams that always seem to run across the road on the apex of the turn, scary stuff.
More details on said car?
Will have my Gtr on the rd with everyone in a few weeks hopefully basically bought it got ripped off but stuck with it I gutted the interior got new carpet just waiting for my seats from being reupholstered the wiring was rooted basically learned to fix it all myself just little bits and peices left and will be ready to drive. Its a white 32 Gtr with the plates GZill4... Hope no one thinks the plates are shit lol only ones that weren't taken which were the best I could think of haha
Yeah can't wait. It was rough when I got it but ive fixed it up as I can when I can. Can't wait to bring it out
Hey man :)
Keen to see your car man, hopefully we'll have a cruise/lunch organised once the weather clears up :)
Will be good to see another white 32 GTR getting around. Also good to see that you have stuck with it, when these cars are running properly they are a ton of fun, when broken not so much.
Welcome dude and hopefully you can get along to one of our runs when this weather clears up
Keen as to
Go for a cruise meet some new people let everyone know when she's ready
Do you get many from toowoomba going on day cruises etc? When are they usually
The regular cruises consist of (the regulars) Chris, Tom, Nick, Myself and Clinton + about 2 or so that turn up once and never come back lol
And we'll usually do them on a Saturday, or a Sunday if Mondays a public holiday
Edited by Captain Natro
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
