Mirrors are off the car to get resprayed
Good to hear lol seeing I looked over the car for a few minutes and couldn't see it till you pointed it out ha think you should fix my boot for money lol? Seeing your car made me.... In my pants so I'm thinking about taking my engine out and just tidying it right upYour car is amazing !
I think I could have a look at it for you. Thanks hearing compliments like that makes all the hard work keeping it in that condition all worth while
Yeah be gd to tee up a day for you to have a lOok at it , Im gunna strive to have my car looking as nice as that keep the work up i hope I'll have mine as close to as nice as yours one day
I couldn't believe it when I saw how small it was...
Seriously, I thought he had totalled his mirror or something....like, folded it back and scrapped the shit out of it :D
Tom, you of all people should know how particular and fussy I am when it comes to the vspec
Fussy is good. At least I know that should I ever need a panel beater, I'll be well taken care of :)
Might have to get you to tag along one day when I go looking for a new car. Could use your expert opinion/tools to supplement my meager knowledge.
So when are we going to do another run? Wanna drive the old girl as much as I can, while I still can ;)
Edited by me_larr
Happy laps is only 2 weeks away, we could roll down to that?
But... They'll be back on by happy laps time right?
I dunno. I have told the painters that I am in no hurry for them to get painted. Then once painted I need to get around to actually fitting them back to the car
I will never understand you Chris :) QR is like the safest place to drive around on....one could safely assume that the 15mins that it takes to get thru Toowoomba on the way to QR are probably the most dangerous minutes of the whole trip!
Ya soft cck :P
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
