Well done mate. Great vid. A little blurry and shaky but excellent work. :)
Thanks Tony, yeh unfortunately the camera focused on the dash which kinda screwed up the video :D Shouldn've had it peeping up over the dash a bit more like in the intro....but ahwell lol, hopefully a gopro next time round for some decent quality footage!
U need to get urself an RB man ;)
Locking up second gear was a major PITA it's like rolling into the turn at 100 pushing your clutch in putting it in second a slipping your foot of the pedal.... Squirrelly stuff
Will your next box be more gentle? Bit more gentle and you can have the car for the quarter and a bit of circuit ;)
Haha nah man, will be just as harsh but with a decent sized stall... I enjoyed today alot, but its not where my passion in Motorsport is :)
That thing is gonna become a mongrel lol :D I've been in V8's with stallies....crazy shit
Btw that was very delicately written Nick ;)
I want it to be a lumpy surging pig of a thing... It's a toy, I have the diahatsu for sensible stuff.
And yer, you've gota watch what you say about circuit work around here :P
+1
I keep telling him this, even his Mrs has one...although only just lol.
+2
Leave your current beast as a daily and pick up a cheap 32/33 so you can look like one of the cool kids. :)
Why? It blew past you in the corners. :)
For a stock as a rock sedan, she moves. Need to sort out brakes and tyres and well be right. :)
Only as if I cornered hard my battery fell out, I just think you'd enjoy the RB gurgle more
That's it, my car needs a Name.
...bearing in mind that the original Godzilla (Gojira) is actually a male (unwanted surprise there lol)
I still cannot come up with a name for my car. Needs to be named after a creature that is either very rarely seen or even mythical
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
