Fair enough. But shit hey, when you're up close and personal with the paintwork you sure notice a F-load of scratches, chips and dents! I swear there wasn't a single mark on the old girl 6 years ago!
I don't need to be up close and personal these days to notice imperfections haha
Ok kents, so we still gonna do this today? I need to syphon some fuel and pick up Brian.....Brian I'm gonna need your addy at some stage my phone's out of cred/plan.
Would much prefer the meeting time to be 12 as I'm half seedy
Yeah its still on
