No tissue can soothe the hurt in my heart...
Boss was happy I was OK so I didn't get my butt kicked so that was a good outcome :)
Glad you didn't get your butt kicked. The big question now is........ will she still let you come out and play with us?
What happened?
Driving fast on bumpy roads with 4 yr old worn tyres.
She took the 1st (relatively sedate) run ok but the 2nd (more aggresive) run she started to understeer more and more with each corner. I chose to maintain my pace and understeered off the road and nearly plunged into a creek. Over corrected to avoid the creek and spun onto a gravel patch (luckily not a tree). The impact of hitting the gravel ripped my front lip off :(
Have done that road numerous times and have always driven within my limits. The one time I choose to be a noob and ignore the feedback the car was giving me, this happens...
I make no excuses for my lack of professional driving skills but I think a true pro would have chosen to not drive the car at that pace in the first place.
Yea she's OK with you guys. Her wish is that we perhaps tone it down a little.
Maybe now she'll let me spend a bit more for happy laps :P
Edited by me_larr
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
