Who fixed it for you?
She got a new lancer, it was about time the oldies settled on what car they were getting. All the questions the old boy was asking me was driving me insane
Pretty sure you can figure this one out, Chris.
Guard needed some massaging, intercooler brackets needed straightening, and some plastic welding was done. All corroded/broken bolts were either removed or drilled out with new ones put through. Definitely wasn't a straight forward job but it got done one weekend. Paint was done by someone unknown to me but it was certainly better than the paint previously on there.
There...I've given you one very distinct clue already as to who done most of the work as it happens to be his specialty :)
Man of many skills - some of which I'm just beginning to discover.
Lancer evo X bathurst?
Think its afm from what I can find out pretty common problem not sure how reset ecu other than scan tool I've got one to do obd2 but not obd1
Just disconnect the battery and tap the break a couple times, turn lights on etc, turn key etc etc....to bleed the system of all power. I also left my old liner disconnected for a couple hours to make sure she was well and truly in reset mode when you fire it up the next time.
When I first do this to mine it won't idle... Second start is fine
Well now you'll have to give it a chance to learn the engine again. I had to do this for my GTST when I put the intercooler on and also when I put the pod on. There's actually a procedure to *helping* the eccs learn...like, a set way that you should drive it so that the computer can fine tune all it's tables (seeing that all engines are different but the computers all have the same maps etc etc)
But yes, if it's chuggy/surgy I'd go over all your vacuum lines, pressurised pipework and all your sensors. Give it all a tighten-up and clean with contact/carb cleaner - your engine will love it (even if it doesn't fix that particular problem)
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
