Are u coming down to the drag day later this month, it'd be good to have another auto present to take these cog swapping neanderthals to school ;)
Come to Lakeside you big farken girl. I'm coming to the drags to get flogged v the least you could do is Lakeside.
I actully have to work man had an order come in yesterday for 2100 sausage rolls for the apostolic church :/.... And they all need to be baked that morning :(
Anyone know who's got white skyline in gatton ?? Drove past my place I waved but it was dark so couldn't see much lol
Nah I don't know him, but I've seen the car. If its a 33 its rocking a massive mega sonic bov and keeps chucking peg leg skids when I see it.
You'll soon see mine roaming the mean streets of Gatton ;)
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
