o/ give a homie a wave!
New old girl? Caldina?
Can do but your car and its colour (best colour btw) is so low key, I only spot you once you're really really close.
Yea, Caldina is the "new" old girl. She's being promoted after a couple years in the shadows.
Awesome man, good luck with the Evo's!
As for the pulling over business - each to their own I guess.
You won't be disappointed in the evos, I went for a run in an evo 7 awhile back and shit the thing went for a stocker
Okies...each car had their pros and cons. Haven't made up my mind. Gonna think it over real hard and decide if I want to proceed or wait for more cars to come onto the market. If I decide to go ahead, gonna get the owner to take the car in to a specialist to give it a full once over (mechanical, electrical, exterior/interior). If the owner says "No", I'll walk.
An Evo isn't really something I truly want. It's merely a compromise with the little lady and my current circumstance.
Anyone keen for a drink and lunch on the 4th?
Always keen if I have spare time. At this point, I'll say Yes!
Hopefully we'll actually get to do something this time :P
Great Leader has spoken, guys. Get to it! :worship:
Haha I'd rather partake in events that require two balls ;) (don't take that the wrong way you pair lol) ....reference to that trackdays meme :P
I'd actually do mini golf but that's as far as those old people extreme sports go :D
I haven't been in the silver Slart
Greg ( #@Sick_R31 ) has been in the abomination twice
And Tom in it twice, once with a broken box
That's because you are scared of a real car that can corner.
Gladly I have not been in the abomination yet.
yeah i'd be f*cking terrified if I was in that thing and saw a corner coming up
Only time I have been for a ride in it was after I fitted coilovers to it. I was drunk at the time. Did sh*t myself on one corner though
