Maybe we need to distract Nick when Chris Rogers is around next and see what happens
Nick skitzes out and yells at mr Chris to gtfo of my car... Very short tempered if anyone touches/damages my car or my guitars
You don't mess with a mans car
So we can fill the abomination with your gee-tars and then burn it all?
LOL, you've spent so much of your hard earned on this car, spending a fraction of that to make it GTA proof should be your utmost priority at this point in time.
Apart from brakes, diff, a proper gearbox and an RB :ph34r:
And a lot of high proof alcohol to burn it.
Hey I have a turbo LSD diff in there and this gearbox has over 3 grand dumped into it and shifts like hulk hogan kicking you in the nuts :P
i kinda think it sucks too. i don't like how spastic the driving is, nor do i like not being a black gangster. i bought san andreas the other day on PSN but i am yet to download it because it takes 10 years because my internet blows..
Edited by Seano350GT
Gatton Clifton road......hey Clint? ;)
What up heffer creek?
What u mob doing on my proving ground lol (gotta watch for trucks up in dem der hill blins kroners make derm sity folk stoppa there breefin n whartknot)
Lol I've been told it's a very scenic route through there with gorges and bridges and all sorts of pretty stuff :P
I wouldn't mind going along it?
It is a nice drive just yer wild life and trucks cutting corners are an issue
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
