I didn't go but I ran into the abom on the way to Brisbane :P
Sounded hot. Would have loved to have taken it on in the Caldina for a couple hundred metres to see if it goes as good as it sounds.
Nick's lucky we met on the Warrego :ph34r: :ph34r:
Caldina would sh*t all over the ahole :P
So glad everybody had fun :)
I feel kinda bad having to withdraw simply because I don't really have a decent vehicle atm.
Now if only Kristian can hurry up and get me my car LOL
Well as soon as you get it I'll be dragging you with to the next event :P
