Been a while and I have a question for you fellas.
Anyone know a good dentist in town?
I need him/her to be good, reliable and not take me for a ride - you know, like one of those horror dentists on today tonight that perform multiple procedures on your teeth that you don't need.
I've suddenly developed a crack in one of my molars. Hurts a little when I bite on it and it's very sensitive to the temperature of the food I eat :(
Dr Fisher / Fischer at the Highfields clinic is pretty good - very professional and honest, wont send you off with 4 new tires if you know what I mean ;-)
They have a 2nd spot now. At the 7 springs medical centre on ruthven opposite Kmart.
Had his wife Paola attend to me today. They're great but I had no idea dental work was so expensive LOL
Hay guys ill be coming to tbar for a few days in about 2 weeks and was wondering if you guys got and meet ups going or if y'all want meet up and talk all things skylines over a coffee or something :)
Are you coming down on a weekend?
I think most of the boys would be up for a feed and strop on weekends.
I am by all means not the main organiser here...I don't even have a car ffs LOL
Best to give the boys a headsup and exact date/time :)
Hey mate, pm me or post here I'm going on the scouting run on Saturday for cc and the weekend after is cc. But like I said pm me/Chris/tom and we'll sort something out... I could go a double short expression with 2 sugars lol
I see you went to the highfields one ;-) You like 'em there? They're pretty good eh
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
