I'm at work :)
Gay
Put a 4.11 in my bro's 13 just the other weekend - he's in love ;) Goes well with the 6 speed.
Nick, stay away from the 13
Timm, keep an eye on Nick..
:D
Gay
Xmas holidays just around the corner....
Awesome
You guys talking about the diff ratios but what about the type/quality of the diff?
I happen to have a brand new ATS 1.5way super silent sitting here if anybody wants it :P
Suits S13/180/r33/s14 29 spline half shafts.
I must say I am very subtle :whistling:
Awesome, Nick gets nice 4.11 gears and Tim gets the Nice cruisey 3.6s for his NA slivia because the car should be for cruising the highway lol
Ummm nooooo....Timm gets the 4.11 for a bit of extra torque back there ;-) Goes a lot quicker thru the gears....N/A SR with 6 speed and 3.6 or whatever it was is a recipe for slloooooooowww :(
:P
So subtle :)
And how many dollarydoos is said diff thingmydo?
Looking for 1.3k. Trying to get back most of what I paid for it a while back. Still in its box and even that's in immaculate condition :P
I have all these surplus items from the 180 in my collection and I'll have to slowly move them. Wife said so.
I'm up for it too!
Although at this point in time, it's tentative. In a little bit of a pickle currently and hoping to get it resolved in the next couple days.
If not, then I'll have to pull out.
Where do we meet?
Is this about your testicles?
I'm up for it too!
Where do we meet?
Meet at HCP?
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
