Hey ppl
Sorry for the earlier post..got the dates wrong :spank:
Thinking bout a cruise this Tuesday (26/04/2011)......
Say start at 9am and back by 3pm
Drive somewhere....stop off for lunch and a photoshoot etc.
Chit chat...get to know some other drivers and see some other cars...the usual stuff
Let me know if you are interested and we can take a call if we get a few cars
Nothing flash...no crazy stuff....just a normal get to know more people thing..open to whoever
Cheers
Jeremy
https://www.sau.com.au/forums/topic/361786-cruise-on-tuesday-26042011/
keen. is it still double demerits on tuesday?
sadly it is.....but then again...its a nice day 28 odd degrees.....and if anyone wants to risk getting points..thats their choice
Personally im up for the chance to meet people and get a few snaps
:thanks:
:thanks:
ok so we tentatively have....
2 R33 GTSTs
1 R34 GT-T
1 R32 GTR (clayton you up for it for sure??)
cmon people...get off your ass n come along....will be fun :yes:
hey guys,if my work doesn't call me in,i'm very keen to meet and greet and have a casual cruise.due to pub hol it's worth some bucks if i get called in.hope i can get along!!
Edited by GT ARRRGH
im down wheres the meet point
Right....im waiting to get more responses and will get everyones numbers and msg you details directly...hope that suits??
As of now we have
3 R33 GTSTs including mine :3some:
1 R34 GT-T :cheers:
1 R32 GTR :worship:
1 more R33 GTST (Garth) :thumbsup:
oh n 1 R33 GTR (if Richard can make it):yes::no:
last minute addition 1 180 sx (Kevin) :thanks:
Edited by jez NF
OK EVERYONE PLZ PM ME YOUR NUMBERS......il msg you the final details. We meet at 9am sharp and leave by 9:30am or so.
Should be a three-four hour drive in total (in case you need to estimate fuel etc)....i recommend filling her up and we can take it from there. No BP stations..only some GULL ones so the more gas you have the better just to be safe.
I have Brendans, Keatons and Kevins numbers already.......
Looking forward to this one.....should be fun :banana:
:thanks: Jeremy
Edited by jez NF
RIght....confirmed numbers as of now:
Keaton - R33 GTST - phone number received - cruise details sent
Keatons friend - R33 GTST - plz pass on the details Keaton...n send me his number when you can :)
Kevin - 180 sx - phone number received - cruise details sent
Brendan - R34 GT-T - phone number received - cruise details sent
Clayton - R32 GTR - phone number received - cruise details sent
Richard - R33 GTR - phone number received - cruise details sent
Garth - R33 GTST - number??
me - R33 GTST
Awaiting confirmation:
Craig - R34 GTR
Hi Jeremy, sorry mate don't think I'll head up, just too far from Rocky - will use over a tank of fuel and just spent the day driving around Kalamunda. Catch up with you all soon, have a good cruise! :thumbsup:
thanks for the heads up Craig....il see you soon for sure...next cruise is up your way...promise :yes:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
