LONGINES FLAGSHIP: BATTERY OPERATED DRESS WATCH
WORTH $1500+ NEW
SELL FOR $700
CHRIS 0478058818
LOCATED IN SYDNEY
(SAME AS THE BLACK FACED ONE IN THE PICTURE)
cheap cheap cheap.... for what it is anyway!!!
im pretty sure i had this well before they came out!!! (ie i have had it for a few years aothough only wore it about 10 times due to having 60+ watches!)
60+ watches wow! Cant say i know someone with 1/10 of that many watches HAHA
back in the day i used to collect them when i had spare cash to throw around..... i had / have some pretty damn good ones, some rare ones, and some pretty shitty ones.... to tell you the truth i have not even worn some of them.... hehehehehe
everyones got their a hobby or something to spend their money on, each to their own i guess.
maybe one day hahaha
Its a nice watch, good luck with the sale bud
Cheers,,, it is a nice watch.... it looks good when worn as a dress watch with a suit etc...
no just the watch as you can see (i have lost the other bits and pieces - they are somewhere at my parents place in Adelaide)...... $450 or there abouts and it is yours..... i am located in brisvegas at the moment..... i will be moving further north in about one months time.....
give me a call on 0478058818
?? :S
u do no what u-boat watches are yeah?
a submarinarer or deep sea dweller i guess.... handy for when you are 12800 feet below the surface and your sub breaks down and you need to swim up to the surface.....
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
