the time has come to realy think about my performance mods on my r32
i was going to stick with the RB20DET but i think it would be
much easyer to extract the power i whant from the RB25DET
so my questions are as follows.
do the rb25 gearbox mounts line up
do i just unplug the r32 ecu and plug in the r33 ecu
or do i have to rewire the whole car
and most importantly
do i have to go through reagency
mel i know you have the rb25 in your 32 so what can you tell me
what other pitfals may i come across
dose any one know any one who can help me with this project
i have herd of some one who ran the rb25 with the rb 20 ecu
but i dont think it ran verry well over heating and such
any help would be much apreciated :)
https://www.sau.com.au/forums/topic/36255-2532/
  • Replies 72
Skidmark give me a buzz or pm, ill be able to help:) Ive got some stuff to get you started if thats what you want to do. hope this helps Matt Regency shouldnt be a problem if you have made sure all is done properly. Or just put the rb20 engine cover on the rb25 and not many people will be able to tell the differance
https://www.sau.com.au/forums/topic/36255-2532/#findComment-722817
matt
i was reading a diferent thread about putting a rb25 in a r32gts4
they had trouble with the sump clearing the cross member
is this the same with the GTST
i have also had a couple of people tell me to leave the rb20 in it
because you can get more top end power out of the rb20
than you can get out of the rb25
what do you guys think do you think this is crap
i do because even if you did get that power out of the rb20
it would be unstreetable
input please :boobies2:
https://www.sau.com.au/forums/topic/36255-2532/#findComment-724153
than you can get out of the rb25 .....
Did you ask them where/when/how? It would be interesting.
That extra 0.5L will give you a bit more torque off boost and bring a turbo onto boost a bit quicker. From what I have seen RB20 and 25 can make similar power (peak) with similar mods, just the RB20 needs a few more revs to do it. But you can never deny that cubes do make a difference, that would be like saying turbos dont make a difference or revs dont make a difference, of course they make a difference - everything else being equal.
The other side is, if you blow up an RB20, they are a very cheap engine to replace, and with a 2530 hanging off them.....killer. Alot less hassels, with registration (just inform regency of the engine swap), changeover cost, resale. You can buy a 2530 new with all the bits to fit it (bolts, adaptors, oil and water lines, etc), for 3K.
https://www.sau.com.au/forums/topic/36255-2532/#findComment-724421
skidmark, dont know about the RB20 being stronger, it does have a lower CR, which helps it handle more boost. I am making over 300rwkw with an rb25, stock internals - its strong enough for me:)
If you have the dollars (around 4.5K) just buy a RIPS 3L engine, with sump already adapted. His GTS4 is running 10s with this engine, certainly scare a few GTRs:p
https://www.sau.com.au/forums/topic/36255-2532/#findComment-725383
mate if u only want 250rwkws, then keep the rb20. The price to put a rb25 in ur car then get 250rwkws will prolly cost double to that of just slappin on a decent turbo onto the rb20.
theres a good chart going around which allows u to choose a turbo for a hp level. Being a rb20, u want a good turbo like hks that can spool up quicker then others. For 250rwkws, somethin like a 2835 would maybe be ideal.
https://www.sau.com.au/forums/topic/36255-2532/#findComment-725813
unfortunalty the 2530 will puff short of 250rwkws. however as steve already mentioned, due to the rb20 having a lower CR, the engine wont mind some more boost over 1bar, and hks turbos are really efficeint still after 1 bar, so it may get really close thou.
The 2835 will get u over that mark, but it will be a lot more laggyier then the 2530, and being a rb20, u will feel it alot.
Perhaps speak to a few about a 2540, a bit laggier then the 2530, but should also be a trade off over the 2835. Otherwise choose a 2530, and do other mods that may help u get there, like adding toluene sometimes when u want to use all the power.
https://www.sau.com.au/forums/topic/36255-2532/#findComment-725870
