http://www.skylinesaustralia.com/forums/at...achmentid=11528
2540 rated at aprox 340ps at 1bar i think
2835 rated at aprox 360ps at 1bar
I think steve said the hks turbs are all measured at 1 bar. So u could wind more boost into the car easily. Also search the forums, think someone a while ago had a huge post about his 250rwkw r32 with rb20.
cya
https://www.sau.com.au/forums/topic/36255-2532/page/2/#findComment-725888
  • Replies 72
theres a few shops around here that sell good second hand turbos. Speak to someone like D1garage. they will give u good advice on what is best for u. then if u want they can source a turbo for u. other then that, look on ebay, these forums, and other shops in adelaide, like hikari performance, city jap parts have cheap turbos all the time.
https://www.sau.com.au/forums/topic/36255-2532/page/2/#findComment-725955
I have seen a 2530 on RB20 make 230 at 1.2bar with 8200rpm redline. It was James (D1 Garage) cefiro, and it went bloody hard - you are looking at an easy 12 second car with that sort of power. Jut be aware that your gearbox may not like it too much, so make sure your tyres arent too sticky:)
With a 2530 you will get a big fat midrange and will come on boost early (ish). 2835 on grepins car is making 274 at 1.3bar, but will have alot more lag than a 2530.
It depends on your driving style. If you dont mind a bit of lag, go a 2835 (or even a T518Z) - if you want something with more down low, go a 2530. anther one to consider is the 2535, but once again it will have more lag than a 2530.
Having 8.5:1 CR, you can run 1.5+bar all day with a good tune and be very safe - so no probs there.
D1 Garage sell a new HKS2530 with ALL the bits (oil line fittings, water line fitting, snout for outlet, actuator (I think), etc, etc) for $3K. Second hand you may be able to save around 1K or a bit more, but for peace of mind, and so you dont end up having to buy more and more bits to make it fit - the new kit is pretty good value for money IMHO.
Give them a call, or better still drop in and see them - James lived in Japan for 4 years, has heaps of connections over there, has seen alot of different setups, and I am sure he will be able to help find the right turbo for what you are after. He has saved me a fortune, as I originally met him looking for an RB25DE head for a 3L conversion. After chatting to me, he talked me out of it, as he assured me I didnt need to go that path for what I was after. Tell 'em I sent you too, more discounts for me later:p.
https://www.sau.com.au/forums/topic/36255-2532/page/2/#findComment-726095
thanx enrico and steve
you have both been a huge help
but seeing my car is still pretty much stock i guess i should get a few other things first
like fmic, oil catch and cooler, boost gauge and controller, dump pipe. you know
all the basic stuff i was also thinking maby one of those sub zero plenums
and i guess if the rb20 blows in the feuture i can always do the
rb25 thing then
thanx again guys and i might see yas on the next cruse :boobies2:
https://www.sau.com.au/forums/topic/36255-2532/page/2/#findComment-727558
i went into D1 garage and they had a greddy boost gauge (second hand) for $120. also a mate of mine bought the same gauge (same model gauge not the actual one) off them a few months before for $120. So i went back to buy it for $120 and they jacked up the price to $150 and wouldnt budge (yes it is the exact same one), even know the had it on the net still saying $120. i had $150 but thats not the point so i didnt buy it, this sh!ts me abit.
https://www.sau.com.au/forums/topic/36255-2532/page/2/#findComment-751597
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
