  • Replies 72
Depends on where on the pillar its mounted. Tim Ireland told me if its on the pillar, as long as its no where the head can reach its ok. Went on to say they are otherwise illegal due to an increased risk of head injury in an accident (Of course it will Tim, just before your head goes through the A pillar)
https://www.sau.com.au/forums/topic/36255-2532/page/4/#findComment-770783
whooo i installed my power up 2 stage boost controll this week end
I cant boost it up yet because my boost gauge has not arived yet
dose any one know what 7 mmhg's on the factory boost gauge = in PSI
and also doese it matter which vaulve on the dsbc you use for the low and high settings
thanx guys you have been a great help so far
https://www.sau.com.au/forums/topic/36255-2532/page/4/#findComment-774556
According to some sources, the stock intercooler can be responsible for up to 7psi drop at higher revs, so this means you are actually producing 20psi boost to see 13 at the plenum.
I wouldnt do it. Keep the boost around 10psi with a stock cooler if you want the turbo to last. This is pretty much the safe limit for a R33, may be a bit different for a 32 though.
https://www.sau.com.au/forums/topic/36255-2532/page/4/#findComment-775368
sorry dont know.
Highly recommend you just find a good tuner and pay them whatever they want to do a good tune - if you get bargain prices, you get a 'bargain' tune - think about it, if someone asked you to do a tune, and it would cost you say $500 of your time, but they only wanted to pay $200, would you still do a full tune, or just a $200 dollar tune?
I have found you get what you pay for, and the sweet taste of a cheap tune will wear off pretty quickly when the car isnt running the way you know it should. I had to learn the hard way:p
https://www.sau.com.au/forums/topic/36255-2532/page/4/#findComment-775700
yeh i was only going to talk to the top tuners eg boostworx teilbrooks and rpm and maby
morpower i dont know yet i havnt herd much of them
im not so much worryed about the price i was going to ring them tell them what i want ask them a few questions and se which had the best customer service and most willing to help
i hate it when mechanics snub you off and try keep you in the dark soon as that happens i usualy pull my car right out and go to the next shop
i had one place want to pull my steering rack out and send it to melb to get recond but i did not belive there was any thing wrong with it so i took it to bedders in modbry and the said that it was fine all the other namless place wanted was a few extra bucks i think
but me no that silly
https://www.sau.com.au/forums/topic/36255-2532/page/4/#findComment-776424
    • UPDATE: Yes the GSP Axles are compatible. I installed it on my R34 today and they are working a treat! Turns out that the S13, S14, S15, and 200 SX all used the same axles as the HR34, and ER34 NA models. Which is 2 bolt x 3 pairs.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
