Clearing out the shed and selling my turbo to make way for something bigger and better.
Brakes, $500 for the lot; negotiable.
All were in good working order when removed, BMC has been kept wet since removal, rear calipers will be basically useless for everyone, but pads and rotors are always handy. Won't separate unless you can find someone else to buy what you don't want/need.
S14 4 pot front calipers w/ all hardware & hard lines
S14 1 pot rear calipers w/ all hardware
RDA S14 slotted front rotors
RDA S14 slotted rear rotors
Nissan rotors to suit R33 (plain)
S14 BM44 NON-ABS
1 set Acre Street Fighter pads (front)
1 set QFM A1RM pads (front)
1 set Genuine Nissan pads (front)
1 set Silverline pads (front, unused)
1 set Bendix StreetRoadTrack (rear)
1 set QFM A1RM (rear)
(S14 front, requires machine, 29mm)
(S14 rear, good to go, 9mm)
(R33 front rotors, good to go, 29mm)
Tial MV-S 38mm external gate, with optional water cooling, brand new, only taken out of the box (which arrived today...) for photos. $400. Firm.
2860 Hi-flow, journal bearing, .64 rear, with HKS Hard intake, Comp cover, inlet, and outlet all powder coated in textured black. enlarged waste gate port (currently at MTQ being done), less than 10,000k's since rebuild. Never run above 1 bar.
$800 with HKS intake pipe, $600 without.
(Exhaust housing not pictured, will obviously be included).
Located in the Northern 'burbs.
Can be contacted on here or on 0408961657. SMS messages will likely be ignored.
Cheers!
Dave.
Turbo SOLD!
Price drops!
Brakes now $450 neg for the lot!
Tial Gate is now $375! BRAND f**kING NEW!
HKS Intake kit still available, pics up soon, $200 ono!
Shit's awesome. Tell your friends!
  • 1 year later...
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
    • I saw your intro update, are you sure you've actually had a starter motor failure? You mention it could be the alarm causing it. I'm assuming you've got a no start issue, but what are the exact symptoms, as there could be a few reasons it has stopped wanting to start.
