I am almost finished removing my pump but I cant get the cradle out so the pump is still stuck. I managed to unhook the pump out of its cradle but the cradle is still stuck to the bottom. The tutorial I am using says to lift a clip on the bottom of the cradle but I cant feel a definite clip. Does anyone have a pic of the clip side of the cradle, I need to visualise what I am putting my hand on.
There's not a clip as such, there's a mounting bracket on the floor of the fuel tank that the cradle hooks in to. IIRC you sort of push it down then left to get it out. I dont remember exactly, but its quite easy. You're probably assuming its more difficult than it actually is!
Yeah I am sure it is easy, I am just not doing it right. I just wish I could see what it looked like down there so I knew where to push it. Bloody tank is full as well so my hand is swimming in high octane fuel. How long can your skin be in fuel for? So you reckon push down on it and slide to the left?
It's on the drivers side facing the front on the tank
Ok im wrong then. I thought it was sort of on the bottom, drivers side, so you push down (to get it past the set of hooks) the left while keeping it down (towards passenger side) to slide it out. It was a few years ago now.
OP - give it a gentle push around to see which directions it will go. It should move say 5-10mm "down" to get past the hooks, then slide out.
  • 2 years later...
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
