I just upgraded to a 3076, so I have the old highflow that was on my stagea
I don't have alot of detail as the car came with the turbo, but I know the following
Journal Bearing
Steel exhaust wheel
Excellent condition - wheels are excellent and virtually no shaft play
Stock R33 housings machined to suit
It probably would be best suited to RB20.
$450 for a quick sale
Pics tell a thousand words
https://www.sau.com.au/forums/topic/363593-t3-highflow-turbo-450/
Shipping to melbourne would be $25
It made 185rwkw untuned through an auto at 12psi. Should be capable of 220-230 through a manual at more boost with appropriate tuning. I get fullboost on the street around 2500-2700
