Hey people,
as you may or may not know, I'm the person who organises all the official merchandise for SAU-NSW, and I'd like your help with coming up with some new ideas for what bits and pieces we can explore next.
Please have a look and post some ideas here: http://www.skylinesaustralia.com/forums/topic/363018-s-a-u-n-s-w-merchandise/
And yeah, if you have any Stagea-specific (or any model, for that matter) stuff you'd like to see, let me know.
https://www.sau.com.au/forums/topic/363766-s-a-u-n-s-w-merchandise/
I have a Stagea hoodie and shirt from SAU QLD. As for future merchandise, how about thermal brew mugs? Like the ones you see at any coffee shop going for a fortune. Just don't make SAU NSW brew mugs cost the Earth lol.
I voted hoodie!:thumbsup:
If it had a Stagea silhouette on it; even better, but not fussy.
I'll be looking into the hoodies and I already have an idea in my head for a Stagea-specific hoody, as well as some for the major Skylines/GT-Rs, maybe even the old 240Z. And yeah, I'll be in contact with the current Qld President to see what we can work out.
As for the thermal mugs, I've tried to chase them up before and they WILL be expensive, no doubt about it. :(
repeat post from NSW Merchandise subforum but...
SAU.NSW number plate (with predrilled holes) has now been fabricated.
It'll be on display at the NSW AGM
It's for hire over weekends for Members' photography purposes (- but never meant for fixed speed cams).
Nick gets first bash :rolleyes:
The ones we attach for midnight speed runs through "safety" cameras are the OzFoz ones, aren't they Terry?
:P
^ ^ ^ oh dear, how did you find out? :woot:
1 pt for 70km/hr in a 60k zone along P'matta Rd whilst crossing Burwood Rd Safety Cam last month - yes with my Foz. Seniors suffer ADD as well as dementia Nick.
F**k I thought I'd forgotten about it until you brought it up again!
Anyway, back to MERCHANDISE everyone! More Ideas?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
