R33 Air Conditioning Condenser SOLD PENDING PAYMENT
R33 rb25det charcol canister SOLD PENDING PAYMENT
RB25det sump $30
R33 sr2 wing needs paint $30
R33 gtst sr1 front wiper motor $30
R33 gtst sr1 rear wiper motor $35
R33 gtst sr1 climate control $35
R33 gtst sr1 bonnet hinge set $15
R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET $50
R33 RB25 skyline power steering reservoir with lines $20
RB25det sr1 stock injectors all work fine but some have broken plasic ends but can replaced $20
R33 Air Conditioner Compressor with lines as seen in pic $50
RB25det sr1 aac valve $40
fiberglass vent (uncut vent) $50
R33 gtst sr1 abs unit and bracket $60
Rb25det sr1 flywheel $40
R33 gtst coupe sr1 door handle's $30
R31 sr3 grill $10
R31 sr3 bits lot $15
R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$25
R33 gtst light garnish $30
R33 centre interior light plus other? $25
R33 turbo oil drain pipe $10
rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $70
r33 horns $10
Nismo muffler 2.75mm inlet with 4.5inch tip $100 plus rear section that suits r33 free with muffler
RB hard oil turbo line $25 (not sure if its rb20 or rb25)
RB hard water turbo line 1 $25 rb20 rb25?
RB turbo hard water line 2 $25 rb20 rb25?
R33 gtst window wiper set $ 15
R33 gtst sr1 passenger side electric window switch and loom $45
R33 gtst sr1 2door seat belts(not sure if its complete) $50
R33 gtst sr1 air con units that sit behind the dash $90
RB20 RB25 Coil Pack Mounting Brackets(might be some bolts missing) $20
pioneer reverse camera bought it 2 years ago for $100 from jb hifi but never used it. $25
vr v6 commodore sedan fuel sender and pump(pulled from running car but hade different plugs to myn) $40
r33 boot latch with plug $20
R33 boot and fuel lever $15
R31 1989 oz spec bonnet latch and lever $15
R33 a/c receiver,drier sensor $30
rb25det fuel modulator with bracket$25
R33 gtst R/H drivers door glass $40
R33 gtst L/H drivers door glass $40
R33 rear window $70
R33 gtst front fenders rolled and liped $170 for both
R33 stereo brackets $20
R33 sr1 dash trim(needs a clean and paint) $40
R31 sr3 4door window wiper and headlight indicator switch stalk(in good working condition) $25
r33 sr1 bonnet in primer$100 has a small dent(can send pics)
R31 oz spec sr3 89 dash painted in black with the correct die paint and half day preping the dash(hard to scratch but if you do, the die paint can be touched up with out a trace. The dash pad is still in stock brown but in good condition. what you see in the pics is what you get. Only selling as im going custom dash for track car. Items are a bit dusty as they have been sitting in my shed $50
R33 gtst false rear wall $20
R33 gtst sr1 coupe rear quarter trims LEFT & RIGHT they just need a clean but in good con $50
RB25det stock dump on black vht $20
R33 gtst rear bar with gtr pods both will need repair $50
r33 gtst sr1 power window motor regulator LHS $80
r33 gtst sr1 power window motor regulator RHS $80
I have r33 interiour parts, pm for what you after
pm me or sms 0435 888 239
Will post at buyers expense
  • Replies 116
R33 gtst sr1 climate control SOLD PENDING PAYMENT
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
RB25det sump $30
R33 Air Conditioner Compressor $40
R31 sr3 grill $10
r33 horns $10
vr v6 commodore sedan fuel sender and pump(pulled from running) $40
R33 rear window $70
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
R33 gtst rb25det hicas computer $60
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
ARP RB20 RB25 HEAD STUDS BOLTS KIT NEW NEVER USED $170(was going to build a forged rb25 for my 31 but now need money for another project)
ARP rb25 Exhaust Manifold Kit new never used $100
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
ARP RB20 RB25 HEAD STUDS BOLTS KIT NEW NEVER USED $150(was going to build a forged rb25 for my 31 but now need money for another project)
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET SOLD PENDING PAYMENT
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
R33 bonnet in black primer has a small bend in lip $50( can get pic)
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
R31 1989 sr3 front calipers( pulled from running car but have been sitting for 3 years) $30
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 gtst sr1 air con units that sit behind the dash, heater cores $90
R33 rear window $70
R33 gtst rear bar, will need repair $25
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
r33 gtst sr1 power window motor regulator d/s $80 SOLD PENDING PAYMENT
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 gtst sr1 2door seat belts complete $50
R31 1989 oz spec bonnet latch and lever $10
R33 rear window $70
R31 oz spec sr3 89 dash painted in black with the correct die paint and half day preping the dash(hard to scratch but if you do, the die paint can be touched up with out a trace. The dash pad is still in stock brown but in good condition. what you see in the pics is what you get. Only selling as im going custom dash for track car. Items are a bit dusty as they have been sitting in my shed $40
R33 gtst rear bar, will need small repair $25
r33 gtst sr1 power window motor regulator passenger side $80
R33 gtst rb25det hicas computer $50
R31 1989 sr3 front calipers( pulled from running car but have been sitting for 3 years) $20
Dave
ARP RB20 RB25 HEAD STUDS BOLTS KIT SOLD PENDING PAYMENT
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
Rb25det sr1 cas with bracket $50
Dave
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
Dave
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
r33 gtst sr1 power window motor regulator passenger side $70
Dave
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
Dave
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
Dave
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
