Cusco Adjustable Pillow Ball Tension Rods
Part number: 233 473 A
Suits R33 GTR
$350
Cusco Front Negative Camber Upper A Arms
Part number: 232 479 A
Suits R33 and R34
$350
Both parts are brand new, still in the Cusco boxes.
Located in Mentone, VIC
https://www.sau.com.au/forums/topic/364439-brand-new-cusco-parts-r33-and-r34/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
