Item Summary: 1988 NISSAN CEFIRO a31,
Asking Price: $14,000
Condition: Used
Reason for Selling: want something more sensible
Delivery Methods: PickUp
Contact Info: 0403557352
Extra Information:
I've decided to get rid of my Cefiro.
I am the first and only owner in Australia (have all import papers still) and have owned it for about 5 years now.
Reason for selling/swapping is I've started going to uni and need something more practical for the next few years.
$14,000 or swaps for a Manual, IS200 with the luxury interior or 3rd Gen Honda Odyssey
(or some similar jap/euro styled car)
Please no commodores etc, I don't care how hektic the sound system is or how good it bakes that one tyre.
Specs are bellow.
1988 Nissan Cefiro
Engine/Drivetrain:
S13 Blacktop SR20DET conversion (has done under 3000k's since rebuild)
20 though oversized Wiseco Forged Pistons
Eagle H-Beam Rods
Fully rebuilt head
Cosworth Metal Head Gasket
Rocker Arm Stoppers
8 Brand new Rocker Arms (genuine nissan)
Tomei Poncams 256/256 11.5mm lift
Denso 550cc injectors
HKS GT2530 (Purchased new)
Nismo Engine Mounts
SR20DET 5-Speed Box (Freshly Re-Co'd)
Apexi Power FC D-Jetro
Custom 3" metal intake
Greddy Dump Pipe
Modified Midmount Hybrid intercooler
Custom intercooler piping
Mechanical 2way LSD
HKS Remote Mount Oil Cooler with Trust Core
Alloy Radiator
Extra Capacity Sump
Exedy 5 Puck Brass Button (5000km old)
Custom 3" Dump Back Exhaust (tucked up nice and high)
High flow 3" cat
Bosch 023 Fuel pump
All heater hoses etc were replaced when rebuilt (or removed if unnecessary)
Suspension & Bracing:
Racing Logic Coilovers 9F/8R
Ikeya Formula Tie Rods
Ikeya Formula Lock Spacers
KTS Adjustable Toe Arms
KTS Adjustable Castor Arms
R32 GTR rear sway bar
Unknown Jap Adjustable Camber Arms (gold colouring makes me suspect ikeya formula)
Full 5 Stud Conversion
R32 Skyline Front Brake Upgrade
Solid Cradle Spacers
All traces of HICAS removed.
Cusco Front Strut Brace
KTS Rear Strut Brace
Aesthetics:
Late model interior (suede instead of carpet stuff)
Late model Tail Lights
Late model non projector headlights
VIP Tint all round
New weather shields
Recaro Reclinable Drivers side Bucket seat
HKS boost gauge
Nismo Shift knob
Pivot fan controller (used to read water and oil temps)
Autech Edition Bodykit
White Work Emotion CRKai's 17x9 front
White Work Emotion CRKai's 18x9.5 rear
Engine is making 200rwkw at 16psi
I had this engine built with maximum torque and response in mind.
Full boost by 3000rpm and pulls until limiter
I wanted to have it tuned for 22psi+ but the HKS wastegate would only support 16psi safely
should crack 220+kw with a decent EBC
https://www.sau.com.au/forums/topic/365051-a31-cefiro/
  • 3 weeks later...
  • 3 weeks later...
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
