In Melbourne, Frankston.
Will ship at your expense. I suggest e-go.com.au for the larger stuff, very cheap.
$50 for all four
Tsuchia JDM Wheels
17x8 +35
17x9 + 38
Black power-coat, great condition
Comes with used 235, 595RSR on the 8"
!!!!!!!!Cracks in one 8". Buckle in on 9" Wheel!!!!!!!!!!!!!
$280
JDM Dish Wheels
18x7.5 +32
18x8.5+35
Some rash
$180
R33 GTST standard dampers with lowered springs
This is them installed on the car.
$180
R33 GTST JDM dampers and springs
On the car.
$390
R33 GTST ARC Swaybars
$55
R33 GTST boot lid
https://www.sau.com.au/forums/topic/365281-arc-swaybars/
17's and 18's all gone.
sorry bud, someone else got in just before you.
dampers and springs are all working and not leaking. only came out of the car for more track oriented items.
swaybars are the same, realistically I could have left these on the car. they are lighter than the whiteline bars i use and are
meant to provide the same handling. but i liked the whiteline so changed back.
https://www.sau.com.au/forums/topic/365281-arc-swaybars/#findComment-5864445
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
    • Yeah you can. Cable tie the gauge to a windscreen wiper, or run it into the car and hold it with one hand, or have the neighbour's kid run alongside and tell you what it says.
