Hi
After the front housing off a HKS GT2835 Pro S to trial with the KAI turbo. After talks with Hypergear, Stao has told me that the front with the anti surge slots might be the cause of the lower then expected power output. He can make me a housing but means I have to be without the turbo for a while so thought I would try and get a hold of a Pro S housing if anyone has a wrecked Pro S with good condition housing.
Long shot but thought I'd give it a shot
Thanks
Callan
https://www.sau.com.au/forums/topic/365311-hks-gt2835-pro-s-front-housing/
