Hey all,
Got the following parts to trade or sell.
Genuine HDI FMIC for R33 GTST. Has the genuine HDI hose clamps(some of them anyway), the internal fin design, the mounting point design etc. Asking $350, note this is attached to my car, read further below.
Oil Cooler Kit. At the moment, this is an EOI but may get rid of it. Kit cost about $400 brand new. Its from Justjap. I haven't fitted it but I bought it off a guy here. Want my money back. $200 FIRM.
Turbosmart supersonic BOV. Comes attached to the pipe which connects to the stock R33 Turbo. This will swap straight into your car. Almost brand new. $170
Electronic Boost Controller HDI $75. Hi Lo includes everything you need. This thing taps into factory loom. NFI where but there must be shit out there to tell you how to install it.
R33 quater panels. Pretty good condition. Includes badges and indicator lights, sonic silver. $70 each(passenger side has door ding from some f**k wit, not that bad either).
Passenger side air bag. Get this bastard cheap, $100!
R33 tail lights, sonic silver. $100 ono a pair
Also got a set of Tein coilovers which are too hard for my liking. Will trade these for regular, aftermarket R33 GTST suspension. Bilstein shocks etc. $700
Got a set of bilstein shocks here with standard springs. I need to get these tested. I don't know if they are "flat" but they feel too soft. EOI on these.
NOW THE TRADE PART
I am after the following:
Metal intake pipe 3" or 4" to suit an R33 GTST
Suspension, Show me what you have. I don't have a great deal to spend so factor this in.
Return flow intercooler (permitted I get rid of my intercooler)
Gates timing belt or other heavy duty timing belt, something new.
New water pump for R33 GTST Series 2
Aftermarket radiator(with or without thermos if available) must not be leaking.
PM me guys. If you want my intercooler, ill need a couple of days to organise my self a new cooler so factor this in. No time wasters please. Dont low ball. I'm open to offers. Photos on request but really everything is what it is. Everything works etc.
All parts do not include post(maybe Ill be generous). Can post or pickup in Sydney!
PM me.
If you've got parts I need, Ive got the money you want.
Edited by SargeRX8
$580 to your door for cooler, all piping, and the oil cooler setup delivered via Ego. Just got the estimate on their site and it was around $30 bux but that was guesstimate size weight etc.
Edited by SargeRX8
any pics of the bov? will it fight an rb20?
If RB20 has the exact same pipe with bends, then yes it will fit.
Its the pipe from the turbo to the cooler.
No idea where its from. Came with my car. From factory I doubt they come with the faceplate fitment but thats how it came in my car so thats how its being sold. It looks pretty mint too. $80 to your door via registered post. Ill PM you.
I need a timing belt ASAP. Buy more gear, fund my timing belt lol.
Edited by SargeRX8
GTR radiators won't fit the GTST they are abit longer... Got my self my waterpump and timing belt.
Would prefer to trade the cooler with someone locally for a return flow cooler. Currently in talk with a chap in melbourne about a cooler change.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
