i've got an auto meter shift light that hooks up to the coil, power and earth. as there are 6 coils on the rb25 how do i hook it up? do i conect it through the loom at the back to all 6 or do i just need to conect it to one of them, if so which one? any help would be much appreciated. thanks
https://www.sau.com.au/forums/topic/366040-shift-light-help/
I have a tacho with a shift light and that has power,earth,illumination (when ur lights go on) and signal, that u just tee off from ur loom, I think it is yellow with a green stripe, or green with a yellow strip, something like that.... you dont hook it up to your coils
253990_226367924055773_100000477008080_959234_3201748_n.jpg this is the wire i have hooked my digital tacho up too on my 25.. it should be a medium size green one (( not sure about colour been a while since i done it ))
i just used one of them splices where u lay the two wires next to each other and push the steel pins down never missed a beat
make sure i lay the ecu plug out and get the right wire !!!
(((@@ you do this at ur own risk if u make a mistake dont came back on me mate @@))
:cheers: :cheers: hope it helps tho i would take a pic of mine but its at the machanic for the next 2weeks :cheers: :cheers:
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
