Selling these as ive bought another car which has most of these parts aleady installed so i no longer need.
Parts located in Sydney and would rather sell locally unless an interstate buyer covers interstate postage
Trust GREX oil cooler and relocator $650 trying to sell local if possible.
needs one the fittings on the relocator replaced otherwise good.
post-1164-0-63769300-1306927666_thumb.jpgpost-1164-0-56531300-1306927676_thumb.jpgpost-1164-0-54802300-1306927689_thumb.jpg
Tomei Type A poncams $600 inc postage These are for BNR32/BCNR33 (RB26DETT).
The Type A cams are designed to get stable idle and raise low-mid RPM torque,
the duration of EX camshaft is shorter. No head work required, simply drop in.
A252X A269IN lift in ex 9:15
Twin high mount manifold came off RB26 T2/T3 size $600
Sard 600cc injectors $500
R32/GTR A Pillar pod gauge holder(new) $40
Greddy cam gears to suit RB26(new)$400
HKS dump pipes(new)$700
Jeccs Z32 AFM $450
x 4 Auto Gauge smoke ceremony gauges 3 stepper type one non (new) $300 for the set
throwing in sender plates and gauge panel for R32 GTR Boost oil pressure water temp oil temp
Sard FPR genuine $80
Tomei sump baffle kit $170 for RB26
feel free to pm me for more infromation and postage prices pick up also avaiable,prices are firm at this stage.
I was told it was new yes, and it looks to be!(i bought it second hand)but it hasnt been put together as yet. i can send see pics if your still interested.
apologies, inbox should be good now.
forgot to mention im unsure on the ks on the cams i did buy them second hand but there seems to be very little wear on them , practically new!
Dumps and Pod holder SOLD
Cooler and relocator price drop $600
gauges still available and selling very cheap for a set with all you need to get them going,steering wheel also available!!
cooler/relo down to $500!!! bargin,Gauges and Momo steering wheel still available and going cheap!
will be posting them on ebay by the end of the week if unsold by that time,get in quick!
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
