Now sold:
-Rims
-Tailshaft
-headlights and indicators
Still Available:
-5 stud $800
-front pipes $150
-diff $250
-Engine- 26/30 $4000 including wiring loom, ecu, turbos etc
-intercooler (no pipes)$200
-Centre console $100
-manual conversion excluding gearbox $100
-Complete boot interior $100
  • 2 months later...
Update:
Still Available:
-5 stud hubs $800
-diff $250
Also have an Rb26/30 which was removed from the Cefiro. It includes wiring loom (modified cefiro loom), ecu, turbos etc and has new rings and bearings. $4000
I also have front pipes for this set up for $150
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
