1993 Nissan Skyline GTS-t.
Had a prang in April - someone made a turn in front of me. Insurance (JCI) said that the salvage is worth $2k according to some auction place (can't remember the name, i've got it written down somewhere, will advise later) so i guess I'm looking for around that price although i am open to offers.
First and only Australian owner - purchased in 2001.
Hasn't seen much driving in the last 3 years.
Windows are tinted to darkest legal tint - driver's side window has some scratches in the tint but the rest is good.
Serviced every 5000-8000kms. Have all service receipts since purchase.
Polyurethane bushings
Reconditioned turbo replaced when the factory ceramic turbo died - "good for 400hp" said the mechanic at the time - dunno what brand it is, but it's larger than the standard - i've only ever run the stock boost, so never got to experience the extra power... oh well...
Rims are the standard ones, but have been chromed or something by the previous owner to make them shiny and look quite nice when they're clean - i cleaned one up a bit so you can see.
Tyres are BF Goodrich 225/50 ZR 16s and have heaps of tread as i haven't done many kms on them and i'm too old to do burnouts.
Splitfire coils that haven't seen much travel at all (probably 1000 - 2000kms if that? I suppose i can check my receipts and figure it out) which i've taken out and put the standard coils back in (one of the standard coils is dodgy). I'll sell these separately.
JVC head unit. bit worse for wear and the "forward" button doesn't work, but the unit still plays CDs/MP3s and radio.
JBL 2 way 4"x6" front speakers
Kicker 3 way 7"x10" rear speakers - you don't need a subwoofer with these installed. Well, at least i didn't...
3" exhaust from the cat with 3" straight through muffler
pod filter
AFM used to be dodgy, but since been fixed - just needed to resolder a connection on it and hasn't given me a problem since i fixed it a couple of years back. (FYI, advice to anyone who has a dodgy AFM and has nasty stalling issues like i did - just unscrew and pull out the plug, re solder it and it'll be like it never happened!)
Also have a Consult Port->RS232 adapter, which helped my diagnose my AFM issue.
apart from the obvious, the passenger door and rear quarter panel is scratched/dinted, the rear bumper also has a couple of scratches/dints but most of the rest of the car is fine. I can take more photos on request.
Location is in Point Cook, Victoria.
Pics are available here - http://franksemails.com/skyline-wreck/
If you want a pic of something specific, let me know and i'll put it up.
https://www.sau.com.au/forums/topic/367340-r32-gts-t-wreck-for-sale/
  • Replies 93
Posted Images
Looking to sell the car as a whole at this point.
After 7:30-8ish on weekdays is a good time to take a look. Weekends are ok too most times depending on what i've got on. PM me if you want to arrange to take a look at it.
Edited by verger
Had a query regarding fixing the AFM. Just thought i'd post details here so everyone knows. The problem that i had was that the socket's solder had broken, so they needed to be resoldered. Been a few years since i did this so my memory may be a bit scratchy :)
In the pic you can see my AFM. (1) Remove the plug from the socket, and then (2) remove the 4 screws - once you've done that you can lift the socket and it should reveal 4 or 5 long metal wires which are attached to some other part inside. The solder on my unit was quite brittle and broke off quite easily. I think i also had to remove the plate to have easy access (3 and 4) to where the wires were supposed to be soldered to (or maybe i didn't have to remove the socket at all and could get to it all from under the plate - can't recall exactly). All you need to do is resolder those wires back where they were soldered and you're done.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
