1993 Nissan Skyline GTS-t.
Had a prang in April - someone made a turn in front of me. Insurance (JCI) said that the salvage is worth $2k according to some auction place (can't remember the name, i've got it written down somewhere, will advise later) so i guess I'm looking for around that price although i am open to offers.
First and only Australian owner - purchased in 2001.
Hasn't seen much driving in the last 3 years.
Windows are tinted to darkest legal tint - driver's side window has some scratches in the tint but the rest is good.
Serviced every 5000-8000kms. Have all service receipts since purchase.
Polyurethane bushings
Reconditioned turbo replaced when the factory ceramic turbo died - "good for 400hp" said the mechanic at the time - dunno what brand it is, but it's larger than the standard - i've only ever run the stock boost, so never got to experience the extra power... oh well...
Rims are the standard ones, but have been chromed or something by the previous owner to make them shiny and look quite nice when they're clean - i cleaned one up a bit so you can see.
Tyres are BF Goodrich 225/50 ZR 16s and have heaps of tread as i haven't done many kms on them and i'm too old to do burnouts.
Splitfire coils that haven't seen much travel at all (probably 1000 - 2000kms if that? I suppose i can check my receipts and figure it out) which i've taken out and put the standard coils back in (one of the standard coils is dodgy). I'll sell these separately.
JVC head unit. bit worse for wear and the "forward" button doesn't work, but the unit still plays CDs/MP3s and radio.
JBL 2 way 4"x6" front speakers
Kicker 3 way 7"x10" rear speakers - you don't need a subwoofer with these installed. Well, at least i didn't...
3" exhaust from the cat with 3" straight through muffler
pod filter
AFM used to be dodgy, but since been fixed - just needed to resolder a connection on it and hasn't given me a problem since i fixed it a couple of years back. (FYI, advice to anyone who has a dodgy AFM and has nasty stalling issues like i did - just unscrew and pull out the plug, re solder it and it'll be like it never happened!)
Also have a Consult Port->RS232 adapter, which helped my diagnose my AFM issue.
apart from the obvious, the passenger door and rear quarter panel is scratched/dinted, the rear bumper also has a couple of scratches/dints but most of the rest of the car is fine. I can take more photos on request.
Location is in Point Cook, Victoria.
Pics are available here - http://franksemails.com/skyline-wreck/
If you want a pic of something specific, let me know and i'll put it up.
https://www.sau.com.au/forums/topic/367340-r32-gts-t-wreck-for-sale/
  • Replies 93
Posted Images
Looking to sell the car as a whole at this point.
After 7:30-8ish on weekdays is a good time to take a look. Weekends are ok too most times depending on what i've got on. PM me if you want to arrange to take a look at it.
Edited by verger
Had a query regarding fixing the AFM. Just thought i'd post details here so everyone knows. The problem that i had was that the socket's solder had broken, so they needed to be resoldered. Been a few years since i did this so my memory may be a bit scratchy :)
In the pic you can see my AFM. (1) Remove the plug from the socket, and then (2) remove the 4 screws - once you've done that you can lift the socket and it should reveal 4 or 5 long metal wires which are attached to some other part inside. The solder on my unit was quite brittle and broke off quite easily. I think i also had to remove the plate to have easy access (3 and 4) to where the wires were supposed to be soldered to (or maybe i didn't have to remove the socket at all and could get to it all from under the plate - can't recall exactly). All you need to do is resolder those wires back where they were soldered and you're done.
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
