Just would like to confirm if an air flow meter from an R34 NEO RB25DET will work on a S2 RB25DET from an R33... I have heard they r the same unit but I'm sure the one on my car atm has E60 at the end of the number and the 34 one reads E61. Both have pink stickers I realise so just wondering if the E60-61 makes any difference.
Thanks
Liam
https://www.sau.com.au/forums/topic/367625-r34gtt-afm-work-on-s2-rb25det/
