CameronBNR32 Posted June 22, 2011 Share Posted June 22, 2011 Would anyone happen to have or know the ATTESA E-TS Pro ECU connector pin id? I am installing a Motec M8 into a R33 GTR and need to rewire the throttle position and engine speed from the motec to the attesa ecu but cannot find any infomation on what wire is what. I can only find the image below, so any help is much appreciated. Thanks. Link to comment https://www.sau.com.au/forums/topic/368646-attesa-e-ts-pro-ecu-and-abs-unit-connector-pins-id/ Share on other sites More sharing options...
paulr33 Posted June 22, 2011 Share Posted June 22, 2011 just find the normal BCNR33 ECU pinout diagram and wire the TPS and speed as you please should be piece of piss to find Link to comment https://www.sau.com.au/forums/topic/368646-attesa-e-ts-pro-ecu-and-abs-unit-connector-pins-id/#findComment-5878304 Share on other sites More sharing options...
CameronBNR32 Posted June 25, 2011 Author Share Posted June 25, 2011 (edited) The car doesn't have the stock ecu/loom in it anymore, so I couldn't trace the wire that way, I did find a R32 diagram which I found the pin ids on. I'll attach it so if anybody else needs them in future. That's all done now but now I can't get the tacho signal to work out of the Motec, I have wired it up to a PWM output and set it to their settings for a Nisaan, has 5v on the wire in testing but tacho does not move at all, which I need the engine speed signal for the ETS ECU Is there another way of getting engine speed signal for the tacho/ets ecu, tapping into the c.a.s 1 degree wire? Edited June 25, 2011 by CameronBNR32 Link to comment https://www.sau.com.au/forums/topic/368646-attesa-e-ts-pro-ecu-and-abs-unit-connector-pins-id/#findComment-5882774 Share on other sites More sharing options...
tricstar Posted August 30, 2012 Share Posted August 30, 2012 so after hours of searching with no results, I've resorted to a thread dig... Has anyone found the elusive ETS-Pro pinout diagram ?? PLEASE !! Link to comment https://www.sau.com.au/forums/topic/368646-attesa-e-ts-pro-ecu-and-abs-unit-connector-pins-id/#findComment-6511162 Share on other sites More sharing options...
