I have put together a kit for a customer who has been Uncontactable so I'm selling this to recoupe lost funds.
Brand new BDG single stage oil pump
Custom machined and prepared bracket to suit any RB
Drive gear for the pump (round tooth type belt)
Drive mandrel and modified oem GTR balancer
Gilmer type drive belt to suit
Modified sump pan with external pick up and head return
Earls braided hose and fittings from sump to oil pump and from oil pump to engine
Modified oem oil pump to suit
All you need to do is have it bolted up to your engine and set the oil pressure once it's running. Everything is there including new high tensile bolts etc etc.
I'm going to ask $3800for the whole lot.
Broken down roughly
Pump $1000
Drive gear $440-550
Bracket $550
Lines $400
Sump $880
Plus the additional modifications to Nissan oil pump and time to nut out the kit say an aditional $1000
It's located in Sydney I have swiped the drive mandrel for another car but a new one will be here by Monday to replace it.
Inspections welcome.
https://www.sau.com.au/forums/topic/368755-rb-external-oil-pump-system/
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
