  • Replies 46
Posted Images
mate this is a skyline website if your wanting to sell your going to have to revise your price, otherwise bumping everyday is not going to help you sell your bike
Mate my price is my price and im open to offers, so unless you're making an offer piss off n keep ya shit to yaself...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
