hi guys
getting rid of some stuff thats lying around that I dont need
Hey guys
Have the following that I want to get rid of since I have no use for it as of this time:
RAYS replica wheel Nuts P1.25 to suit Nissan and others that require a 1.25 thread pitch for wheel nuts.
They aren't used, still in the packaging as I went with longer nuts.
It's 16 nuts + 4 locking nuts + 1 key
Also have a brand new replica Greddy Type RZ BOV with adapter kit etc etc:
I'm after $100 for the BOV and $60 for the wheel nuts.
If anyone from interstate is interested:
Postage for the BOV = $15
Postage for the wheel nuts = $10
Located in Olympic Park SYDNEY.
Please PM me as I check the PM's on my phone, loads quicker then loading this page.
Cheers
Hey guys, I got some gauges that I do not require, going a different setup.
They are DEFI replica gauges, they don't require a control box to use.
They all light up RED or White.
Includes: Wiring, Instructions, Sensors, Mounting plate, Gauge Cup
I have the following that I'm getting rid of still new in boxes, never had a chance to use them:
1. Voltage Gauge
2. Boost gauge in BAR
3. Oil Pressure Gauge in BAR
4. Oil Temp gauge in DEGREES Celsius
5. Water temp gauge in DEGREES Celsius
Some of the gauges for photos:
When they light up:
I'm after $300 for all the gauges. Add an extra $20 for shipping australia wide.
Or if you want everything here, take it for $400. +$30 if you want shipping.
Edited by tiksie
  • 3 weeks later...
  • 3 weeks later...
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
