i have for sale my seadoo xp limited
its a 1998 model with 80 hrs on the clock.
rego exp jan 2012
has a few luxury mods done to it for nicer ride...
Jet Trim seat
hydro turf floor matts
trigger throttle
sticky near new 'stolen money' grips (great when wet)
worx sponsens (makes cornering unbelievable)
engine ALLWAYS flushed, cleaned, Fogged (as req), sprayed down after use.
carbys been rebuilt few months back using genuine makuni kit from states.
i have used the oil feed only once when i 1st got the ski, since then i have mixxed my oil into the fuel at 40:1 to prevent any chance of leaning out/issues
rebuilt RAVE valves, and replaced the rear water valve not long ago too.
come with trailer rego untll jan 2012, new LED lights and plug. 2 speed hand winch with 'skid' slides not wheels.
over all this ski has served me VERY well over the past few years since i have had it. am selling only to upgrade as we require a bigger ski now. ive read on the net that these are THE best sea water skis for jumping/river carving etc etc.
this has been used a about 75% river 25% sea (never launched/beached to prevent ware-ring copping sand there for waring out) only dropped in at ramps.
item is in adelaide and am happy to send interstate.
$4500
    • About $4k brand new, available from vendors in Oz, or via an importer from Japan. Although that is for an R34 box, so you also need to buy the push clutch front plate (brand new from Nissan) and swap that over, and drill the bellhousing for a push clutch slave cylinder.
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
