FOR SALE
Item: Rota grids 18x9.5+30 in bronze, wrapped with falken 452s (235/40/18)
Price and Condition: $1600.
Wheels are quite new and so are tyres, wheels with no gutter rash but has an 1cm scratch on one of them. Tyres with about 80-90% tread.
Fits a DC5 with a little camber at the fronts, and 2-3 to fit comfortable on the rear. Fitment is flush
Pictures:
WHEEL 1
WHEEL 2
WHEEL 3
WHEEL 4
TREAD
Please PM me here, or text me on 0422187638 if you have any interest.
Thanks,
Will
https://www.sau.com.au/forums/topic/369475-syd-fs-rota-grids-18x9530/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
