CHEEP CLEAN TURBO R33 -- SOO MANY GOODIES :)
CAR IS HARDLY DRIVEN NOW, ALWAYS GARRAGED
96 R33 SKYLINE SERIES 2 GTST
LOCATED IN NEWCASTLE NSW
BODY
FACTORY SILVER PAINT IN EXCELLENT CONDITION
LEGAL 35% DARK TINT, 10% on rear window and sun roof
NISMO CLEAR SIDE INDICATORS
TEIN HA ADJUSTABLE HEIGHT AND DAMPER FULL COIL-OVER SUSPENSION
NEW STANDARD ROTORS AND PERFORMANCE PADS
18INCH HP FUSION, 8.5 INCH FRONT, 9 INCH REAR +38 OFFSET
235s FRONT, 245s REAR
COMES WITH STANDARD 16's WITH HEAPS OF RUBBER DUNLOP SPORTS
WIDEBODY ROLLED FRONT GUARDS, PROFESSIONAL JOB DONE IN JAPAN
ENGINE
168,000 KM
RB25DET NEEDS WORK
(USES APPROX 0.25L OF OIL PER TANK OF FUEL)
ORIGINAL MANUAL GEARBOX IN EXCELLENT CONDITION
HIGH FLOW R34 TURBO (OP6 REAR HOUSING, RATED FOR 270RWkW)
APEXI AVCR BOOST CONTROLLER
FRONT MOUNT INTERCOOLER, PAINTED BLACK
STANDARD AIRBOX WITH K&N PANEL FILTER, ALSO HAVE K&N POD FILTER WITH ADAPTOR KIT
OIL CATCH CAN
FULL TURBO BACK HIGHFLOW EXHAUST
STAINLESS STEEL HIGH FLOW CAT-CONVERTER
STAINLESS CANNON
R33 GTR INTANK FUEL PUMP
APEXI POWER FC W/O HAND CONTROLLER, STANDARD ECU ALSO AVAILABLE
INTERIOR
SONY 50Wx4 CD HEADUNIT
12" SUBWOOFER IN BOLTED FIBERGLASS ENCLOSURE (SPARE WHEEL CAN STILL BE ACCESSED, AND ALL FACTORY BOOT CARPETS IN PLACE)
BATTERY BOX WITH LARGER BATTERY IN BOOT
JAPANESE TURBO TIMER
BLUE LED DASH
MONGOOSE 2 PT ALARM W/ 2 REMOTES
FULL SET OF S2 MESH STYLE R33 FLOORMATS
CARPET,SEATS,DASH INTERIOR IS IMMACULATE
AIRCON/CLIMATE CONTROLL
ABS BRAKES,DUEL AIRBAGS,POWER WINDOWS,MIRRORS ETC
MOMO GEAR KNOB
FACTORY S2 LUMBAR ADJUSTABLE BUCKET STYLE SEATS, SMALL TEAR IN DRIVERS SEAT, REPAIRED AND UNDER SEAT COVERS.
ISSUES
ENGINE NEEDS WORK, PUT A 30 oR SECOND HAND MOTOR AND TUNE FOR 270kW
ABS NOT WORKING
AIRBAG / STEERING WHEEL / CLOCK SPRING NEEDS TO BE RE-ALIGNED
FRONT WINDSCREEN CRACK
$9,000 WITH ALL THESE GOODIES (INCLUDING INTERCOOLER, PFC, AVCR, COIL OVERS, OP6 TURBO ETC.)
$7,000 WITHOUT PFC, OP6 TURBO, AVCR
IF NO INTEREST I WILL STRIP THE CAR DOWN AND TAKE IT TO THE WRECKERS,
WOULD BE A SHAME TO SEE THE END OF HER, WOULDNT TAKE MUCH TO START MAKING GOOD POWER
HEAPS OF REGO TILL MAY 2012,
THANKS FOR LOOKING MAKE AN OFFER !!
Pm for Number
Thanks Matt
https://www.sau.com.au/forums/topic/369776-clean-r33-going-cheap/
mad car mate, recommended it to a friend who is looking around so hope he gets in touch.
its weird but yours is almost a match to mine right down to the colour, series 2, Sony head unit, crack on the front windscreen and 235 fronts/245 rears.
small world eh.
  • 3 weeks later...
  • 4 weeks later...
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
