HI All ,
Up for Sale i Have .
Pair Of Ok Silvia Doors $120 Both ono
Pair Of Plastic Silvia Side Skrits Nismo $100ono
Fibre Glass Vented 180sx Guards Pair $100ono
2.5inch Exhuast For S13 $80ono Cat Back
Vicous LSD For S13 Good Conditon $140ono
R33 Front Brakes Hubs Rotors With Brake Line and Even Top Control Arm $330ono
Boost T $25ono
Sony Xplod 15inch Sub in Box 1500watt $50ono
Some Chunky Head Unit lol $25ono
Jensen Amp $40
West Coast Customs Amp $40
2 19ich Mags with tyres $100
Have Photo s Of All Items Will Post Or PM them On Request.
Parts Located In Devonport Message Me on 0417509090
https://www.sau.com.au/forums/topic/370070-silvia-skyline-parts-etc-clean-out/
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
