Hey all
After much thought, I have decided to sell up my toys. As alot of you on here know i allways look after my cars and allways buy and use only the best! Still not 100% sure i want to part with my GTRs but cant have everything.
Car only had a few minor mods done when i purchased it a while back, mods / parts listed below have been added / installed while i have owned it. Car has done 128 XXX KM of which 125 XXX KM of these car was in completly standard form, running stock boost.
I also have FULL ( yes FULL ) history of this GTR from the day it was purchased, stamped NISSAN dealer hand books Nissan service reports, ECT till now ( its a big folder and rare to have these days )
For those who have or have not delt with me befor, I am very particular in how i do things and want things done, I allways buy top quality parts and allways use top quality oils and so on !
ITEM : BLACK 1995 R33 GTR NON V-SPEC - CONDITION : In great condition
MODIFICATIONS :
APEXI Power FC
GARRETT -5 ( GT-SS ) turbo's
NISMO intank fuel pump
NISMO fuel reg
NISMO twin plate clutch
NISMO air flow meters
NISMO LM GT4 rims
HKS lowered springs with rebuilt standard struts
HKS hard pipe kit
TRUST front pipe
TRUST 3 inch exhaust
TRUST air intake pods
SPLITFIRE coil packs
SPEEDLAB 120mm drag front mount intercooler
RDA slotted front rotors
CUSCO oil air catch can
PIONEER stereo with fusion - amp - sub - splits
Tinted windows
Full 3 point immobiliser
Interior is near spotless, Allways cleaned and looked after. Non smoker owners since new!
Car made 352RWKW on 18PSI ! Dyno sheet Available.
OVER $18K in labor and top quality parts have been bought and installed to this GTR in the last 9 months !! Previous to that car was stock !
Only top name quality parts used !
If your wanting a genuine 350KW GTR then this is it.
A full mechanical report including comp test ECT will be provided to show engine is in Perfect condition !
Sure ive missed something but you get the idea.
CONTACT : PM me
PRICE : $25K FIRM
Also if you dont know what your talking about, Please keep your comments to your self !! No test drives !!
PICTURES : will have some up next couple days , or can MMS some.
CONTACT : PM me
Edited by stylz7
https://www.sau.com.au/forums/topic/370389-black-r33-gtr/
Some Pictures below people, Its best i can get at the moment, Its raining down in Adelaide and will be raining for next couple days.
Car has rego till end of year as well.
Edited by stylz7
https://www.sau.com.au/forums/topic/370389-black-r33-gtr/#findComment-5905165
They roughly produce the same figures ( depending on the car and other mods )
My 33 gtr makes 352RWKW @ 18PSI with -5 garretts
Mate of mine 34 GTR makes 368RWKW with HKS 25/30's @ 18PSI
Edited by stylz7
https://www.sau.com.au/forums/topic/370389-black-r33-gtr/#findComment-5908379
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
